Guest Posted March 21, 2008 Share Posted March 21, 2008 help needed please my bike is a r1 04 when i start it up from cold it revs on its own up to 3000 revs which it should on the automatic choke ya ! but it should go back down to 1 1/2 ooo rev when its warmed up but it dunt. it keeps at 2000 rev for about 40 mins even when i am riding it. can anyone help please im pissed off with it. iv been told i need some spray to put it my air box to clean somthing .it this right ???? Quote Link to comment Share on other sites More sharing options...
houdini Posted March 21, 2008 Share Posted March 21, 2008 Spray in your airbox?The only thing I can think of is K&N's filter kithttp://www.poweredbyford.com/store/images/manufacturers/kn/99-5000.JPGIm not sure if that'd sort it, hmmmmm.Think its a reference to air starvation, filter blocked kinda thing. Can you get to the airbox to check, check the air intakes for obstructions etc.You could try recharging your filter, depends on whats fitted. Sure I read somewhere try it without moving off without the filter in, see if that cures the prob, if so get a new one. This is not a definite though, better grease monkeys will be along soon. 8) Quote Link to comment Share on other sites More sharing options...
Guest philgale Posted March 21, 2008 Share Posted March 21, 2008 there should be a twisty thing somewhere....im good with bikes me....on my bike its on the right hand side as you sit on it, on the engine and that regulates the revs so you can turn them up or down.....just dont try it when your moving, i did and turned the revs up by mistake and shot off Quote Link to comment Share on other sites More sharing options...
Voodoo Posted March 21, 2008 Share Posted March 21, 2008 I think what Phil is trying to say is, adjust the Idle screw Quote Link to comment Share on other sites More sharing options...
Guest philgale Posted March 21, 2008 Share Posted March 21, 2008 I think what Phil is trying to say is, adjust the Idle screw thats the one.....told you i had no idea Quote Link to comment Share on other sites More sharing options...
Guest philgale Posted March 21, 2008 Share Posted March 21, 2008 actually iv just read my post again and its on the left of my bike not the right....think ill go back to sleep Quote Link to comment Share on other sites More sharing options...
houdini Posted March 21, 2008 Share Posted March 21, 2008 Reffering to the idle rev adjuster yes?Might help:http://www.r1-forum.com/forums/showthread.php?t=157901http://i9.photobucket.com/albums/a81/WilliamYZF-R1/tickover.jpgAll depends if it was running fine before and its just started to bugger about without you messing, if bought like that it may well be the idle screw been fiddled with. Quote Link to comment Share on other sites More sharing options...
houdini Posted March 21, 2008 Share Posted March 21, 2008 Above was for an 01, this may differ, for your 04http://www.r1-forum.com/forums/showthread.php?t=207794 Quote Link to comment Share on other sites More sharing options...
Voodoo Posted March 21, 2008 Share Posted March 21, 2008 Personally I don't think its the Idle setting either. R1's have a diagnosis built into the dashboard, and when certain revs are showing it can mean different things depending on how high the revs are. The first thing I would try is, turn on the ignition, but don't start the bike, now look at your tacho (rev counter) and does your needle start jumping after a few seconds. Leave it at least 10 seconds, if nothing happens then that is good (If it does jump, let me know how high and I'll let you know whats wrong). The next thing I would do is look at the workshop manual, heres a copy of mine but obviously mines a 98 model. I don't think yours has carbs so disreguard that bit but theres probably still something that can go wrong with fuel injection. I guess another easy thing to try would be the battery and the air filter element.http://i235.photobucket.com/albums/ee259/Voodoo1972/dia.jpg Quote Link to comment Share on other sites More sharing options...
Guest Posted March 21, 2008 Share Posted March 21, 2008 Yamaha has wrapped the wire harness for the instrument cluster around a sharp metal edge in the "crotch" of the fairing stay. It is retained with a plastic tie strap. Pull your windscreen and look straight down between the low beam headlight housings and you'll see what I'm talking about. Mine rubbed through and started popping the ignition fuse at random. It seemed temperature sensitive and defied the wiggle test. It was not water-sensitive. Bumps did not give it away. It only happened on hot days in heavy traffic. I found this not same as you but still could be same reason You might find out something on here m8 http://www.r1-forum.com/ Quote Link to comment Share on other sites More sharing options...
Guest Posted March 21, 2008 Share Posted March 21, 2008 i know its not the Idle screw so i'll change the filter 8) a big thanx lads 8) 8) lack of air sounds right Quote Link to comment Share on other sites More sharing options...
