Guest Posted June 7, 2007 Share Posted June 7, 2007 Um, real novice question here.What do you guys use to lube your chain (if not Scotoiler)?AndHow?How often?Thanks muchly Quote Link to comment Share on other sites More sharing options...
Guest akey Posted June 7, 2007 Share Posted June 7, 2007 Before I had a scotoiler I used chainsaw oil, brush it after a ride or if you use the bike alot every week.worth looking at the lubeman system as well http://www.chainoiler.co.uk/ nice and cheap and does the job well. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 I've got a touring scotoiler fitted Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Ta, gonna look into that one, and the scottoiler aswell Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Ive done around 8k on it so far and still going or should I say oiling Quote Link to comment Share on other sites More sharing options...
Snoopy Posted June 7, 2007 Share Posted June 7, 2007 what to use?engine oil, just wiped on with a clean rag, then finish off with a wax spray too, don't know why, however, I expect I'll shortly get told lots of reasons why I shouldn't use both how often?ummm, depends how much you use it, I'll normally do it a couple of days ahead if I know I'm going out for a long run, but if it's just a quick blast or an unplanned trip, well, then it don't get done! Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Gear oil 80/90 i find works well just wipe off the excess with a rag 8) Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 scottoiler, lots for sale on ebay, easy to fit, works soooooooooooooooooooooooooooooooooooooooooooooooooo well Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Got one myself secondhand yesterday and bugger if i know how it all goes Pipes,tubes all over the place Intructions anyone? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 HhAHAHHAHAHAHHAAAHAHAhahahahaha !Serves you right I had mine fitted at dealers and wondered what Neil was on about ............... easy to fit It doesn't look that easy to me Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Dealers are for peeps with more money than sense Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 Dealers are for peeps with more money than sense and that are crap with anything mechanical or not arsed with getting their hands dirty Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 i use that ceramic oil it seems to last a long time but it turns your chain white Quote Link to comment Share on other sites More sharing options...
Guest Posted June 7, 2007 Share Posted June 7, 2007 viewtopic.php?t=545&highlight=chain+lubeChucky!! Bin dun!! Check out this thread too xx Quote Link to comment Share on other sites More sharing options...
Stu Posted June 7, 2007 Share Posted June 7, 2007 snoppy oil then wax is good the wax helps to keep the oil in Quote Link to comment Share on other sites More sharing options...
Stu Posted June 8, 2007 Share Posted June 8, 2007 Intructions anyone? yes Here Quote Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2007 Share Posted June 8, 2007 What a star ,cheers bud 8) Quote Link to comment Share on other sites More sharing options...
Stu Posted June 8, 2007 Share Posted June 8, 2007 no worries Quote Link to comment Share on other sites More sharing options...
Guest Posted June 8, 2007 Share Posted June 8, 2007 (edited) snoppy oil then wax is good the wax helps to keep the oil in Oil then wax Isn't that was Drew uses on his hair when is goes on the pull Edited June 8, 2007 by Anonymous Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted June 8, 2007 Share Posted June 8, 2007 l always try and lube up the chain after a long ride when the chain is still warm, l don't use a cleaner and reading through one of the links attached below gave some alarming reading as to why not to use W.D.40 on a bike chain, well worth a read that. Even when l had a right good dirty day out off roading with the Gas Gas all l do is jet wash the bike down and relube the chain, its been on for 2 years now and still looks fine. At the mo l am using Kal Gard racing spec clear chain kote with P.T.F.E does what it say's on the can http://www.webbikeworld.com/t2/motorcyc ... a/lube.htm Quote Link to comment Share on other sites More sharing options...
Stu Posted June 8, 2007 Share Posted June 8, 2007 yeah wd40 perishes rubber Quote Link to comment Share on other sites More sharing options...
Guest Posted July 20, 2007 Share Posted July 20, 2007 Stu-m is rightWAXOYL -chains last longer-soak new ones in it and brush- into your fitted ones-this is by far the best -forget about all the fancy stuff Quote Link to comment Share on other sites More sharing options...
