The GOAT Posted July 18, 2019 Posted July 18, 2019 Just got one, felt great in shop but after 2 hrs or riding heavy migraines appearing. Seems to be a hotspot on my forehead?Just ordered new thinner liner for it in the hope it will cure it, see how it goes.Coming from a Shoei GT-Air both of which are small i'd of thought the fitment would be the same?It's noticeably heavier as you'd expect, but not impressed as of yet.Hopefully it needs breaking in?Anyone experienced similar? Quote
JackieOWheels Posted July 18, 2019 Posted July 18, 2019 I could see the Neotec2 is a flip up helmet. Did you order it on the same size as what you normally wear or did you go a size up? I have the exact same problem with mine but I had ordered a size up and have the same problems you have. I never noticed it before but after having worn a full face helmet since the start of this year, going back to the flip one hurts my head. I believe the padding will eventually form to the shape of your head so it may improve after you wear it for a bit longer. I would try a size down though if it is still get a chance to swap it? Quote
Working Class Hero Posted July 19, 2019 Posted July 19, 2019 I have one and I love it.I've never had any issues with pressure points or anything, so maybe it just needs breaking in... Quote
Tankbag Posted July 19, 2019 Posted July 19, 2019 I've got one, if anything now the foams bedded in it's almost too loose. Give it some more time. Quote
