kaidux Posted October 1, 2019 Posted October 1, 2019 Sorry if this is the wrong board, but this thread is just a question based on my Yamaha YS125 2018 model,I recently did a burnout, which resulted in my check engine light coming on, nothing is wrong with the engine as it runs perfectly and nothing has changed in the performance of the bike since doing it, I think a sensor may have freaked out or something over the wheels not moving/functioning properly, and I’d like to know the best way to reset the check engine light.Thanks Quote
Mississippi Bullfrog Posted October 1, 2019 Posted October 1, 2019 Fault codes vary in being cleared. On some they will reset after a certain number of start/stop cycles. Others will reset if you disconnect the battery. Others will retain the code until you clear it using diagnostic kit.Usually there's a way to trigger the code to flash so you know what fault is being registered. Paperclips inserted in the right places and all that malarky. 1 Quote
Jason Brown Posted May 17, 2024 Posted May 17, 2024 How to turn engine management light off YS125 Quote
