Hi and welcome to the forum
It says on the battery quick charge 3A x 1H which means at 3 Amps it will take an hour
I reckon this may well be the max it could take and with your charger being 4 Amp I wouldn't risk it!
Unless its a smart charger and designed for bikes then that way they know how much charge to put in and at what rate
probably that's why i heard from first second something like battery starting boil.
They do fizz a little while charging
but if its boiling then it may be shagged!
has it been left flat?
yeah ofc , i have to add yet that battery have 4 month
Eh? That makes no sense to me.
If the battery is very flat, anything under 12volts, then it won't take charge off a conventional charger. You need to prime it at something under 500Ma. A cheap plug in gel cell charger will do that no problem. You need to raise the voltage back to 12 volts before it will take a charge.
But as Stu says, you really want a charger specifically for bike batteries, usually with an output less than 1 amp. If you don't ride regularly get a maintenance charger that can be left connected. A CTEK 0.8 for example.
