Jamiew Posted February 13, 2020 Posted February 13, 2020 Hi Sorry I’m a pretty much a novice here but was looking for some help. I’ve had a push go zip 2T for a few years now and whenever it shows oil getting low I’ll simply add the oil to the area that says oil under my seat next to the petrol compartment. I’m looking at a 125cc fuel injected 4 stroke. How do you go about adding oil to this. I understand you need to add it with the Petrol? Do you need to do this every time you fill up? As said, sorry to sound like a complete idiot but if you don’t ask you don’t get and I can’t find the info I’m looking for online. Cheers. Quote
Stu Posted February 13, 2020 Posted February 13, 2020 Hi and welcome to the forum you are adding oil to the moped now and that is mixed with the fuel this provides lubrication for the engine In a 4 stroke the only oil you add is engine oil and you change this at regular intervals There is no need to add oil to the fuel it is a case of add fuel and go! Quote
dynax Posted February 13, 2020 Posted February 13, 2020 As above 2T engines require an oil/petrol mix which can be premixed externally or internally as in your current case,4T engines only require petrol in the petrol and oil seperately in the engine same as a car Quote
fastbob Posted February 13, 2020 Posted February 13, 2020 Could I suggest that you purchase the Haynes Manual entitled Basics Techbook . You will find once you understand why something works it becomes much easier to grasp how something works . https://www.ebay.co.uk/itm/193214453857 Quote
