jedibiker Posted December 3, 2020 Posted December 3, 2020 Im trying to replace the right hand oxford grip as mine is faulty, tested with meter. I see there are a mix of oxford grips so how do you get the same or doesnt it matter? Can you buy used? cheers Quote
husoi Posted December 3, 2020 Posted December 3, 2020 have you check here? https://www.sportsbikeshop.co.uk/motorcycle_parts/content_cat/1763 if you ask them usually they will get the right one. 2 Quote
jedibiker Posted December 3, 2020 Author Posted December 3, 2020 1 hour ago, husoi said: have you check here? https://www.sportsbikeshop.co.uk/motorcycle_parts/content_cat/1763 if you ask them usually they will get the right one. Thanks Il have a look Quote
husoi Posted December 3, 2020 Posted December 3, 2020 6 minutes ago, jedibiker said: Thanks Il have a look Make sure you follow the link to their shop here in the forum Quote
jedibiker Posted December 3, 2020 Author Posted December 3, 2020 I did, its only left side, cheers Quote
Stu Posted December 3, 2020 Posted December 3, 2020 4 hours ago, husoi said: have you check here? https://www.sportsbikeshop.co.uk/motorcycle_parts/content_cat/1763 if you ask them usually they will get the right one. Links have to include /#/27907,3203,1186 at the end to be affiliated to the forum Quote
husoi Posted December 3, 2020 Posted December 3, 2020 Just now, Stu 4 hours ago, husoi said: have you check here? https://www.sportsbikeshop.co.uk/motorcycle_parts/content_cat/1763 if you ask them usually they will get the right one. Links have to include /#/27907,3203,1186 at the end to be affiliated to the forum I clicked on the link in the forum then made a search for the grips Quote
Stu Posted December 3, 2020 Posted December 3, 2020 21 minutes ago, husoi said: I clicked on the link in the forum then made a search for the grips That would work for you but supplying the link you have to add the affiliate code to the end of it Quote
jedibiker Posted December 5, 2020 Author Posted December 5, 2020 whats the link to browser before buying, need something else Quote
jedibiker Posted December 6, 2020 Author Posted December 6, 2020 On 03/12/2020 at 22:33, Stu said: That would work for you but supplying the link you have to add the affiliate code to the end of it I cant find the link in the forum buddy I want to order their acf50 now. Quote
Stu Posted December 6, 2020 Posted December 6, 2020 1 minute ago, jedibiker said: I cant find the link in the forum buddy I want to order their acf50 now. It's right at the bottom of the forum and rotates with two other adverts Or just click here https://www.sportsbikeshop.co.uk/#/27907,3203,1186 Quote
jedibiker Posted December 6, 2020 Author Posted December 6, 2020 3 minutes ago, Stu said: It's right at the bottom of the forum and rotates with two other adverts Or just click here https://www.sportsbikeshop.co.uk/#/27907,3203,1186 Ah my usual rush had me look, see bikesure then click away lol.. 1 Quote
jedibiker Posted December 6, 2020 Author Posted December 6, 2020 Sorted, got 32oz acf50 for £25 free post,,,, r8 deal 1 Quote
