I've got my hands on a basket case RF600 and I need a set of carbs for it, would also take RF900 carbs.
Missed two sets on eBay which were £70 each, they sold before I officially took this on, typical!
Anyone got any lying around they would sell?
Maybe after more parts yet too...
Seems you have to be quick with bike carbs these days.
My local garage does a lot of jobs on Rally/motorcross tye  competition cars. One of the popular mods is to fit motorbike carbs, appears it works well for more power and better throttle response.
2 hours ago, iangaryprice said:
Would GSX600 carbs fit? Should be planty of these available.
As it turns out they are 36mm mikuni carbs too, good shout, apparently the engine is canted at a different angle, but I haven't found the angle figures yet, could still work, thanks.
The carb rubbers could take care of the different angles and the carbs may sit at the same angle
As above the carbs (top face of float bowl) should be horizontal. The carb rubbers should hold the carbs horizontal.
You need to check the spacing between the carbs as well. Adjustment might be difficult.
5 hours ago, WD-40 said:
If he got carbs off a different bike would he have to jet them to suit his bike or could he just run them?
More than likely have to be set up fully for the bike
It's ok, luck upon luck!, when I picked up this basket case from the seller (who assured me there were no carbs) there was a box of parts, with carbs sat at the bottom of it, cue one very happy me. I no longer need carbs :-)
3 hours ago, iangaryprice said:
Thats gongto make teh restorationa lot easier. Good find.
I was very pleasantly surprised by the contents of the box, took a lot of items off my eBay watchlist!
