Hi all, i have a keeway superlight 125cc for about 2 years now, its broken down for the fourth time with electrical problems blowing the 20 amp fuses. At 1st i thought it was the solonoid feeding too much power from the battery to the ignition switch on the handlebar but i disconected that from the battery and the starter switch and it still is blowing the 20 amp fuses, im hoping its the injector as that keeps cutting out mid way through its initial start from the ignition switch. And im wondering if it is that, that is the problem to which i can try to switch out the injector and put a float carb in there instead. Thanku in advance
