Are you looking for someone here to sell one?
Or advice on what you should buy?
Having a Speedtriple I use an Abba stand that operates on the swinging arm pivot, I also have the ratchet strap attachment that allows both wheels to be off the ground at the same time.
Its a great bit of kit.
The only down side is that I have managed to ham fistedly scratch the frame where the adapter has dropped out as I tried to fit it - the lesson is to tap the adapters into place before fitting the stand !!
