Guest Posted June 19, 2008 Posted June 19, 2008 Hi my GPZ 500S is making a sound like the exhaust is holed but I cannot find any holes. I tried to pull away a few days ago with the disk lock on(what an idiot) and bike ended up on its side but did not fall hard as I held onto it although the engine did rev high but I am not sure how high. The bike still starts fine and runs fine with good acceleration and the noise is less noticeable when revved over 6000 revs. any suggestions what could be wrong what to look for and what to test. Apart from the noise the bike is as it always has been. Quote
Stu Posted June 19, 2008 Posted June 19, 2008 easy to check the exhaust......start the bike and put your hand over the end if it has a hole/leak it will stay running if not it will stop after a few seconds its hard to diagnose a noise without listening to it Quote
Stu Posted June 19, 2008 Posted June 19, 2008 also location in your profile may help as they maybe a member close by willing to help Quote
Guest Posted June 19, 2008 Posted June 19, 2008 Is there anyway you can record a video off the noise or owt so i can lisson to it and i will be able to help better.Matty Quote
Guest Posted June 19, 2008 Posted June 19, 2008 Hi I have tried covering the exauhsts for about 10 seconds with no effect engine still running but I could not hear any gas escaping. I will try and record the sound tomorrow morning and post recording. On decelaration I have noticed it makes a popping sound which made me think it was the exhaust. I live in Stewarton just outside Kilmarnock. Quote
Guest Posted June 19, 2008 Posted June 19, 2008 if you've dropped it even lightly the noise could well be from your fairing.................the fairing mount is really quite delicate and a slight twist leads to noise at low revs.................believe me i know .......mine's sendin me freckin bonkers.............had a low speed off bout a month ago and sod has rattled ever since.............gunna have to have a new fairing bracket to cure it properly Quote
Sk93 Posted June 19, 2008 Posted June 19, 2008 could have also buggered yer baffles in the can.try "tapping" the exhaust and listening for a bit of a rattle..If somert does rattle, then its very likely one of the baffles has become dislodged, broken, etc... hand over the exhaust should definately stop the bike tho Quote
Sk93 Posted June 19, 2008 Posted June 19, 2008 hand over the exhaust should definately stop the bike tho just remembered.. GPZ500S is twin exhaust.. you'll need to cover both Quote
Bill_on_a_bike Posted June 19, 2008 Posted June 19, 2008 Not an expert, but popping on deceleration could be back fire?I don't think exhausts can cause this though.Please do NOT get worried, i could well be very very wrong. Quote
Sk93 Posted June 19, 2008 Posted June 19, 2008 if it is a baffle come away, then it COULD be this banging around in the exhaust when you come off.. again.. so hard without sound :/ Quote
Voodoo Posted June 19, 2008 Posted June 19, 2008 if it is a baffle come away, then it COULD be this banging around in the exhaust when you come off.. again.. so hard without sound :/ If it is a baffle, I'd have thought you could bang the exhaust with the palm of your hand (when the engines off) and you'd be able to hear it rattling Quote
Guest Posted June 20, 2008 Posted June 20, 2008 Thanks for all reply's it's the exhaust up at the manifold the pipe is corroded. I am now looking to put on a 2 into 1 exhaust any recomendations and where could I purchase one Quote
Guest Posted June 20, 2008 Posted June 20, 2008 Thanks for all reply's it's the exhaust up at the manifold the pipe is corroded. I am now looking to put on a 2 into 1 exhaust any recomendations and where could I purchase one e-bay Quote
