ginge511 Posted June 28, 2008 Share Posted June 28, 2008 Hello all For a while now, when i'm riding me motor ,the second i put it into 2nd gear theres a horrible noise but no power lose or anything?It only happens in 2nd gear, sort of a buzzing noise.Any ideas what it could be?Thanks Quote Link to comment Share on other sites More sharing options...
Voodoo Posted June 28, 2008 Share Posted June 28, 2008 Second gears probably lost some of its teeth Quote Link to comment Share on other sites More sharing options...
Guest Posted June 29, 2008 Share Posted June 29, 2008 When is the noise occurring, when you accelerate or is the noise there from the minute you first try and put it into 2nd??Does it go away after a while or is the noise there all the time??What bike do you have just out of interest?With the little details I can only go back your 2nd " could " be lost some teeth. I would open up your gearbox and have a look tbh. Matty Quote Link to comment Share on other sites More sharing options...
ginge511 Posted June 29, 2008 Author Share Posted June 29, 2008 When is the noise occurring, when you accelerate or is the noise there from the minute you first try and put it into 2nd??Does it go away after a while or is the noise there all the time??What bike do you have just out of interest?With the little details I can only go back your 2nd " could " be lost some teeth. I would open up your gearbox and have a look tbh. Matty Hi mate.When is the noise occurring, when you accelerate or is the noise there from the minute you first try and put it into 2nd??At 1st when it started happening, it started after say 6 seconds when in 2nd gear but know it starts straight after i put it in 2nd.Does it go away after a while or is the noise there all the timeit starts when i put it in 2nd but when i get to 8000 revs it stops.What bike do you have just out of interest?It's an Aprilia rs extrema 125 bike.With the little details I can only go back your 2nd " could " be lost some teeth. I would open up your gearbox and have a look tbhThere's the prob i haven't a clue what im doing Quote Link to comment Share on other sites More sharing options...
ginge511 Posted June 29, 2008 Author Share Posted June 29, 2008 I've been told that i just need a new bearing?Is this true? Quote Link to comment Share on other sites More sharing options...
Fozzie Posted June 29, 2008 Share Posted June 29, 2008 Could be possible. Then again it could be a loss of teeth. Take it apart and look at the gearbox and check each cog. Its a simple engine so it wont take long. 2-strokes always make a buzzing noise that sounds weird untill you give it higher revs though it doesnt explain why its developed the way it has.OH, Sudden brain blast. How many miles has it done???My old RS made a bad noise that got worse and worse then one day *BANG* bye bye engine. if the mileage is high, keep off the bike, get a rebuild kit immediately. Quote Link to comment Share on other sites More sharing options...
