Clothing and weather protection
When riding mopeds or motorcycles it is important that you wear the correct protective clothing to protect you from the weather and to help other road users to see you.
Without the right clothing you can get very cold and wet when riding a motorcycle. Special motorcycling clothing is available which:
protects you from the weather
helps to protect you from some types of injury
helps other road users to see you
By law you must wear a safety helmet when riding a motorcycle on the road. However, you should also consider using the following items of clothing when riding a motorcycle:
visors or goggles
gloves and gauntlets
protective clothing
boots
visibility aids
Safety helmets
By law you must wear a safety helmet when riding a motorcycle on the road. All helmets sold in the UK must either:
comply with British Standard Bs 6658:1985 and carry the BSI kitemark
comply with UNECE Regulation 22.05
comply with any standard accepted by a member of the European Economic Area which offers a level of safety and protection equivalent to BS 6658:1985 and carry a mark equivalent to the BSI kitemark.
Damage to helmets
If your helmet receives any serious impact you should always buy a new one. Damage won't always be visible to the naked eye. For this reason you should never buy a second-hand helmet.
Visors and goggles
A visor or goggles are vital to protect your eyes from wind, rain, insects and road dirt. All visors or goggles must comply with a British Standard and display a BSI kitemark, or they must comply with a European standard which offers a level of safety and protection at least equivalent to the British Standard and carry a mark equivalent to the BSI kitemark (ECE 22-05).
If you need glasses or contact lenses to read a numberplate at the prescribed distance then you must wear your glasses or contact lenses when you ride. You should not wear tinted glasses, visors or goggles if you are riding in the dark or conditions of poor visibility.
It is very important that you keep your visor or goggles clean. You must have a clear view of the road ahead at all times. To clean your goggles or visor wash them with warm soapy water. Do not use solvents or petrol.
Protective clothing
Motorcycle clothing is of two main types:
clothing made from man-made materials
leather clothing
When you are choosing protective motorcycle clothing make sure you look for additional protection for the shoulders, elbows and knees.
Gloves and gauntlets
Good gloves or gauntlets are essential when your ride a motorcycle. Never be tempted to ride without gloves. If you fall off you could seriously injure your hands.
Motorcycle boots
It is important to wear good boots or footwear when you ride a motorcycle. If you wear sandals or trainers your feet will have little protection if you fall off.
Riding in cold weather
When riding in very cold weather your hands and feet can become painfully cold. No matter how good your gloves or boots, the cold will eventually get through. This can cause you to lose your concentration when riding. To overcome the cold you can try wearing thin inner gloves on your hands and an extra pair of socks on your feet. If your hands or feet become too cold, stop and warm up before continuing your journey.
If you're serious about motorcycling in cold weather you should consider buying electrically heated inner gloves or electrically heated handlebar grips. However, these accessories put a large demand on your motorcycle's electrical generator so you should check that it can cope with the extra demands before you buy and fit them.
Visibility aids for motorcyclists
Many road accidents involving motorcyclists occur because another road user didn't see them. Using some form of visibility aid will help others to see you. Remember you need to be visible from the side as well as the front and back.
Wearing fluorescent orange or yellow clothing in daylight will improve your chances of being seen.
Other methods you could use to help other road users to see you in daylight include:
wearing a white helmet
wearing brightly coloured clothing
riding with your headlamp on dipped beam
To improve visibility in the dark you need to wear reflective material. They work by reflecting the light from headlamps of other vehicles. This makes you much more visible from a long distance away.
