Another day, another problem!
Anyone got any ideas why my ninja is juddering when pulling away or in low revs?
I've changed the sprockets and chains but its still doing it? Its only in low revs but you give more throttle its fine?
I'm thinking fuel or mabe air filter? Any ideas?
Some bikes really dont like being at low revs, but if this has only just started happening then I would have a look at the air filter and plugs, they could both need cleaning / changing.
I've changed the plugs recently but the air filter is a bit oily and coated in flies but i think it might be worth investing in one?
carb balance??
I did speak to my local dealer and he said a tune up would cost about 60 quid so i thinks i'll be doing that! Thank you
Check your HT leads and plugs does it stutter when reving?
Na, revs are fine just seems that its struggling for fuel but it is only when about 2000 revs, i'm sure it must be fuel as it has been sat a while?
