Fiddlesticks Posted December 11, 2022 Posted December 11, 2022 The heater wires on my left hand grip have gone, so I thought I'd be clever and re-wire it with new Nichrome 80 0.1mm 38 Gauge AWG 40M Roll 143.9Ohms/m Heater Wire. https://www.amazon.co.uk/gp/aw/d/B015K42M4M?ref=ppx_pt2_mob_b_prod_image Suffice to say, it didn't work. There's voltage to the supply wires, but absolutely no heat to a single wrap of heater element wire. They're in the grooves and not touching, pretty certain. Any tips before I give up entirely? Quote
Grumpy Old Git Posted December 11, 2022 Posted December 11, 2022 The link does not take me to any information however, you say you measure 12v across the feed to the heater wire coil. This would indicate a high resistance or an open circuit in the coil. By my calculations, you should have an output wattage of approximately 240W for a 1 metre length at 12V - This would use a current of 0.083Amps. Disconnebt the voltage and: a) check the resistance. b) connect an ammeter in series (set to 1Amp max) and then connect the feed voltage and see what you get. 1 Quote
fredc Posted December 11, 2022 Posted December 11, 2022 the wire you chose is too high resistance, choose one to give about 6 ohms for the length you're using on each grip 21 awg or 22 awg nichrome wire might do 1 Quote
Fiddlesticks Posted December 12, 2022 Author Posted December 12, 2022 (edited) Thanks both, it was a bit of an experiment really. Giving up as I've found some genuine replacements for not too much on flea Bay. Bigger problems now as the electrics are dead. The blessed ignition barrel or wires thereto have given out (loose connection, which quickly became no connection). At least it happened on the drive rather than halfway down the M53 in freezing temps... Edited December 12, 2022 by Fiddlesticks 1 Quote
