hoycch Posted March 26, 2023 Posted March 26, 2023 I am going to take a test in which there is a bus lane that operates outside the test time. I am required to use the bus lane. The bus lane is some what the same lane as the original lane. It splits into 2 lanes when the bus lane start from a cycle lane. Do I signal when I drive into the red shaded lane? Quote
billy sugger Posted March 26, 2023 Posted March 26, 2023 As you are effectively changing lanes you should be indicating to those behind you of your intentions. Make sure you shoulder check as well 1 1 Quote
bonio Posted March 26, 2023 Posted March 26, 2023 Yes, like he said. Indicate left and cross over the dashed lines into the bus lane. A left shoulder check is necessary to be sure something isn't coming up behind you. 1 Quote
hoycch Posted March 27, 2023 Author Posted March 27, 2023 just out of curiousity, when buses enter their bus lanes, do they put on their left signal? Quote
