Silverfox Posted April 19, 2023 Posted April 19, 2023 I have a lexmoto titan 125 efi starting issues flooding spark plug black and wet changed tps plus filter ok too much fuel going in any idea thanks Quote
Grumpy Old Git Posted April 19, 2023 Posted April 19, 2023 Stuck float in the carb. Hole in the float Dirt in the fuel outlet from the carb causing the float pin (valve) not to seat correctly. Blocked air intake/filter. Quote
Stu Posted April 19, 2023 Posted April 19, 2023 20 minutes ago, Grumpy Old Git said: Stuck float in the carb. Hole in the float Dirt in the fuel outlet from the carb causing the float pin (valve) not to seat correctly. Blocked air intake/filter. It's an efi 1 Quote
Mississippi Bullfrog Posted April 19, 2023 Posted April 19, 2023 Does it have a coolant temperature sensor? If that fails the ECU will see the engine as always cold so make the mixture permanently rich. Quote
Silverfox Posted April 19, 2023 Author Posted April 19, 2023 Don't know but has a engine temp sensor Quote
