conor Posted June 17, 2023 Share Posted June 17, 2023 I have a 2014 ybr125 which had an ignition fault, the engine light was flashing I think it was code 19. I then replaced the ignition and this made no difference. I've done a continuity test on the ignition and the wires leading to ignition and all seem to be fine. I have noticed that the blue neutral light doesn't light up if the fuel gauge is working and vice versa only one seems to work at a time what could this be? It does turn over but doesn't start. Also there is a constant 12v to the spark plug but doesn't raise when turning over Quote Link to comment Share on other sites More sharing options...
bud Posted June 20, 2023 Share Posted June 20, 2023 Code 19 is the side stand switch. But apparently it can also be the connection between the ignition switch and the ECU. Which uses a separate circuit. Quote Link to comment Share on other sites More sharing options...
