techno hippie Posted October 15, 2023 Share Posted October 15, 2023 hi my zontes zt125u won't turn on when i press the unlock button the key fob has a brand new battery the bike battery is fully charged it will only turn on when i press the test button Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted October 15, 2023 Share Posted October 15, 2023 Button on the flob might not be making contact with the switch inside, switch, wiring or circuit board failed? Quote Link to comment Share on other sites More sharing options...
techno hippie Posted October 15, 2023 Author Share Posted October 15, 2023 i've tried a new switch still doesn't work Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted October 15, 2023 Share Posted October 15, 2023 The other is the antenna and its wiring that could be around the ignition. Quote Link to comment Share on other sites More sharing options...
megaross Posted October 16, 2023 Share Posted October 16, 2023 (edited) 14 hours ago, techno hippie said: zontes Found the problem There any flashing lights that show the button press is being registered on the fob? Seems suspect one button works but the other doesn't and suspicion therefore points at the fob. You got a spare? Edited October 16, 2023 by megaross Quote Link to comment Share on other sites More sharing options...
RideWithStyles Posted October 16, 2023 Share Posted October 16, 2023 Had to laugh megaross yes, its a common problem but unfortunately thats not the cheapest solution. Thats what i thought and suggested but hippie has already done apparently. Mind you if the bike is still in warranty, hand it back to the dealer to sort it. If not might do no harm in finding a good auto electrician or trusted mechanic near you, you'll be getting to know them a lot more than ud like. Quote Link to comment Share on other sites More sharing options...
haggis1980new Posted May 2 Share Posted May 2 On 15/10/2023 at 18:48, techno hippie said: i've tried a new switch still doesn't work Did u fix this ?I have same problem Quote Link to comment Share on other sites More sharing options...
