indicator spaceing
craig
just taken my r+g tail tidy off ,and replaced it with an evo-tech one.
Before my indicators where at the side of my number plate but now with this new one they are above the plate and only stick out a little bit past the plateso as there short ones but there still visable .....this legal or not........
technically your indicators have to be a minimum of a legal sized numberplate apart. So if yours poke out the side and you have a full sized plate you should be ok, if you running a small plate then the should be further apart.
Can you not fit the std rear end and indicators for your MoT?
