kanesgranda Posted February 28 Share Posted February 28 I am restoring a 1980 suzuki ts250er and my problem is that the speedometer only works when driven anticlockwise unfortunately the front wheel driven cable turns clockwise. So is it possible to modify the speedometer to run clockwise? Many thanks John. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 28 Share Posted February 28 I used to own a ts 250 about that time my cable went and is was the cable inside the cable that had snapped hope it helps Quote Link to comment Share on other sites More sharing options...
Tinkicker Posted February 28 Share Posted February 28 2 hours ago, kanesgranda said: I am restoring a 1980 suzuki ts250er and my problem is that the speedometer only works when driven anticlockwise unfortunately the front wheel driven cable turns clockwise. So is it possible to modify the speedometer to run clockwise? Many thanks John. Nope. I suppose you could try swapping your forks and front wheel around, so the speedo drive and brakeplate is on the right instead of the left, but that will cause endless problems elsewhere. How did your speedo and speedo drive get mismatched? Either the speedo is incorrect, or the front wheel / brakeplate is incorrect. Quote Link to comment Share on other sites More sharing options...
kanesgranda Posted February 28 Author Share Posted February 28 This bike came as a box of bits, I did consider swapping the forks and wheel around but quickly dismissed that idea. I dismantled the speedo but don't understand how to make it work in the other direction. The spinning magnet obviously induces a magnetic field into the metal dish to make the needle turn .Surely a similar speedo which uses anticlockwise rotation works the same way? Quote Link to comment Share on other sites More sharing options...
Nick the wanderer Posted February 29 Share Posted February 29 Hi, " I dismantled the speedo" could be your answer. Maybe time to have another look in there, something is clearly not quite right. Good luck. Quote Link to comment Share on other sites More sharing options...
