I’m having a go at rattle can painting a motor cycle tank, I have got it prepped & a couple of coats of etch primer flatted down.
Next up is the base coat ( when it warms up a bit ) I am going to procure some vinyl decals & will make sure they are the type that can be lacquered over …
The question is: Do I apply the decals to the base coat & then lacquer over or lacquer then apply decals & lacquer again?
Thanks
Posted (edited)
Paint, decals and clear
Needless to say that you need proper quality materials including the base, clear can damage paint if not automotive quality
Edited by husoi
Exactly what my potential choice of decal supply said.
I’ve got quality ( AKA expensive ) base paint and lacquer.
I went to a respected paint supplier with the base colour code I wanted & used their advice about the most suitable petrol resistant lacquer I could get without going to 2 pack.
Posted (edited)
I really like this guy's work.
In here he explains how to apply the paint and he always uses the same trick to add the decals.
He uses soapy water so he can adjust the decals and then uses heat to dry the water.
https://youtu.be/ZA1gVMtxWuE?si=8tCQSYKZ-YgIudHr
Edited by husoi
Unfortunately I don’t speak Portuguese
