Hi guys, started riding last year so dont know the ins and outs of repairing everything just yet. I had a vintage Honda 125 from '81 and the headlight bulb has just recently died, took off the cover and doesnt look like theres any screws and such to get into where the bulb is to replace it. If anyone knows how to or a suitable headlight replacement/upgrade pplease let me know as im a tad stuck.
Thanks!
If its still the genuine honda light you should just take the screw out on the bottom of the chrome outer rim then lift of the cover complete with the lens. On the back you should be able to gently rotate the bulb holder and take the bulb out. The bulb is then rotated in the holder to get the bulb out. It could be that you dont have a genuine honda light and it had been replaced at some time so it could be slightly different. Take it gently do not force things and when the bulb comes out make sure you install the bulb the same way. The bulb may have offset pins so must go back in the same way.
  • Thanks 1
