Guest Posted July 31, 2007 Posted July 31, 2007 can anyone tell me if i can set the gap on iridium plugs myself I sent this email to NGK and they are not answering the question i asked Hi can you confirm that if i ask a dealer for bike specific Iridium plugsthen the plug gap would be preset to the manufactures recommendations or doi have to set the gap myselfthe reason for asking is i have a Yamaha XJR1300 and orderded DPR8EIX-9plugs which should have a gap of 0.9mm the ones i got have a lot bigger gapthan thisregardsGary and recieved this reply back Dear SirThank you for your enquiry.The spark plug gap for your vehicle is pre-set to 0.9mm. This is thecorrect setting for your motorcycle.Kind Regards.Technical Department Quote
R1 Iain Posted July 31, 2007 Posted July 31, 2007 You can set the gap for whatever the bike requires.. These plugs are good and should not give you any problems...I have to say everytime I fitted these plugs the gap was correct from the box... Quote
Guest Posted August 1, 2007 Posted August 1, 2007 Just had a reply from NGK Dear SirThe plugs should be gapped at 0.9mm, I cannot explain why the plugs youpurchased were not.But you can adjust the gap to 0.9mm for the standard and the iridium typeplugs. 10/10 for speed of responce i'm off in my garage now to set them Quote
Guest Posted August 1, 2007 Posted August 1, 2007 I am a numptyI am a numpty I am a numptythere i said it before you lot start on me had the wrong feeler guages i was trying to set them to 0.09mm instead of 0.9mmSo I am a numptyI am a numpty I am a numpty tra la la lala Quote
Guest Posted August 1, 2007 Posted August 1, 2007 strange mistake, most people use imperial rather than metric or t'other way aboot. Quote
Guest Posted August 2, 2007 Posted August 2, 2007 Obviously not firing on all cylinders at the time .... Quote
Guest Posted August 2, 2007 Posted August 2, 2007 easy done i recon its old age Gary I could blame my mate as he passed me the guages but i wont i should have checked its definatly an age related problem Quote
