crumley Posted May 16, 2009 Share Posted May 16, 2009 thought some new riders may find this usefullRunning Tyres In It's important to understand that running tyres in doesn't just mean scrubbing-in the tyre surface. Scrubbing a tyre surface is only one of the reasons for running tyres in: • A tyre needs to be seated on the wheel. This is not fully achieved when fitting the tyre and it needs to be ridden on with caution to complete the process. • In order to achieve optimum performance, the various components of the tyre (belts, tread strip, etc.) need to correctly bed-in to one another. If not correctly run-in, a tyre may not give the best possible performance. • When new, a tyre has a very smooth surface and in order to obtain optimum grip, the smooth surface needs to be scrubbed in. At first the bike should be ridden as upright as possible. Gradually, the angle of lean can be increased, always ensuring that a portion of scrubbed-in tread remains in contact with the road until full lean angles are achieved. During this time the bike should be ridden cautiously. Hard or sudden acceleration and braking should be avoided because optimum traction levels will not be achieved until the running process is completed. Not all manufacturers use releasing agents during the manufacturing process, but for those that do, the scrubbing-in process will need to take into account the fluid residue as well as the smooth surface. These agents can also contain anti-ageing preservatives and this is why the manufacturers do not remove them before shipping to their customers. Wet weather can increase the required running-in distance by as much as three times. Rubbing a new tyre's surface with an abrasive material in order to scrub the surface in, has little affect. Even very abrasive materials will not scrub the tyre's surface sufficiently for the bike to be ridden hard right away. And besides, the tyre still needs to be seated on the wheel and the various components still need to be bedded-in against one another. Put simply, there is no short cut to running a tyre correctly. Following the fitting procedure, the tyre should be wiped with a dry cloth in order to ensure no residue of tyre fitting lubricant remains. 100 miles is considered a safe distance to run tyres in. When this distance has been covered, the tyre should be checked to ensure correct seating and inflation. Quote Link to comment Share on other sites More sharing options...
stevie16v Posted May 16, 2009 Share Posted May 16, 2009 Pretty interesting esp for new riders like myself! Cheers Quote Link to comment Share on other sites More sharing options...
MtotheJ Posted May 16, 2009 Share Posted May 16, 2009 Thanks Very helpful! Quote Link to comment Share on other sites More sharing options...
Guest Posted May 17, 2009 Share Posted May 17, 2009 Your full of good information you!! Thanks again. Quote Link to comment Share on other sites More sharing options...
crumley Posted May 18, 2009 Author Share Posted May 18, 2009 i want to share all in know and learn from what others know to better ourselves on the road and help stay alive.(the wife would kill me if i died on the bike ) Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted June 3, 2009 Share Posted June 3, 2009 So in short, don't gun it for atleast 100miles?Just got new tyres on the new bike so quite interested in this. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 3, 2009 Share Posted June 3, 2009 Note to self:Doing 110 six miles after fitting a rear tyre is not clever Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted June 5, 2009 Share Posted June 5, 2009 Note to self:Doing 110 six miles after fitting a rear tyre is not clever Did someone once mention something about how many heat cycles a tyre has to go through? As opposed to just milage? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2009 Share Posted June 5, 2009 Note to self:Doing 110 six miles after fitting a rear tyre is not clever Did someone once mention something about how many heat cycles a tyre has to go through? As opposed to just milage? Atleast 2 heat cycles, or so I read Quote Link to comment Share on other sites More sharing options...
