Evening all,
I have a bandit 1200 K4 and when I indicate my headlight and tail light dim as the indicators flash.
I've seen this on old cars before and wonder what the problem is........any suggestions?
Cheers all
Evening all,
Cheers all
On a car, bad earth.
On a bike, I'd guess the same.
Check all earthing points for the indicators and other lights.
have you done anything to the bike recently.. especially wiring related, could be you have some wires mixed up.. otherwise id suggest one of the wires has chaffed and is shorting on the frame..
Yea I thought it might have been an earth problem, the only mod I've done is fit a new can to it.
I'll be fitting some LED indicators soon so hopefully the cause will become apparent then.
Cheers guys
just remember to get resistors for the LEDs.. otherwise, you'll get another problem.. flashing too fast..
