Passed Mod 1 at the Macclesfield Rugby Club this am thanks to some excellent tuition from Bill and Mike at Cheshire Bike Training.
Took it on Yamaha 125 YBR and had no trouble with attaining 50kph, went round the curve at at 20mph in second then just wound it up through the speed check, still in second, did 53kph and 55kph respectively. Ok it was vibrating the nuts off but it did the trick. :wink:
My advice to anyone is don't get fixated on the so-called swerve manouvre, it is not as bad as some of the hype you read and hear. When we were practising some of the guys were touching their brakes and this was causing problems for them.
Also on the emergency stop I didn't even use the clutch, just braked and stalled it, did mirror checks rear life savers and re-started it calmly. No faults recorded. :cheers:
Well done, have copied and pasted your info here..
viewtopic.php?f=47&t=23633
This topic is now closed to further replies.
