Hi
can someone please assist me with this problem, i cant work it out from the wiring diagram.
It concerns the 2 wires which come from the magneto to the rectifier (1 pink and 1 green). it has a 2 prong rectifier so one need to attach one ( currently the pink) to the rectifier and the other prong must attach direct to the the battery for charging purposes.
which leave me with the green wire? what does this attach to? currently it not attached to anything.
i have tested the battery to see if im charging it whilst running , buts only slightly high volts than when not running, the manual states it should be around 8.5 from the rectifier pre conversion. but its only just around 6 v only a faction higher thn when not running the engine.
so i need to fing out where this green wire attaches to and how it all links together so it charges the battery
can any please help
thanks
Hope its not the KE125 I owned 21 years ago! :shock:
If it is, the wirings f***ed, thats why I got shot of it!
  • Haha 1
i cant upload this diagram? what am i doing wrong . its only a small file,
it says
The image must be at least 0 pixels wide, 0 pixels high and at most 1024 pixels wide and 768 pixels high. The submitted image is 1522 pixels wide and 1063 pixels high.
Youv'e answered your own question
the image is to big
  • 14 years later...
