dixie Posted July 13, 2010 Share Posted July 13, 2010 I've noticed I've got a squeaky back brake, dad says it that the underside of the brake pads need greasing As always I know nothing about it, is it easy to do? Should I replace them to be on the safe side? Any suggestions greatly appreciatedThanks Dixie Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted July 14, 2010 Share Posted July 14, 2010 i assume its a disc brake just check thickness of pads if they are ok you can take them out aand put small amout of copper slip on the rear of the pads not the disc side ths should cure the squeak Quote Link to comment Share on other sites More sharing options...
j4ff Posted July 14, 2010 Share Posted July 14, 2010 I would take out the pads clean the dust build up on them.Would also use a toothbrush and soapy water to clean out the caliper before copper slipping the back of the pads and refitting. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 14, 2010 Share Posted July 14, 2010 Permatex car disc brake quiet, works a treat. you use it on the back of the pads in the same way as copper slip, it costs about a fiver for two sachets. Quote Link to comment Share on other sites More sharing options...
