BoB3rt Posted July 19, 2010 Share Posted July 19, 2010 ello,noticed a crack on my rear hugger getting increasingly larger over the past month... today i think i found that the problem is the lock i secure the bike with when at my girlfriends, i think it has been catching on the long thinner part that covers the chain and been bending it well now this crack is rather large and i suppose if i dnt try to amend it soon its going to snap altogether!! is there a way to patch up these flimsy plastics or will i have to buy a new one and spray it thanks! Quote Link to comment Share on other sites More sharing options...
TC Posted July 19, 2010 Share Posted July 19, 2010 Clean it up and fibre glass it underneath Quote Link to comment Share on other sites More sharing options...
hammer5 Posted July 19, 2010 Share Posted July 19, 2010 You could try some fibre glass strips with the hardening resin as a cheaper alternative. Maybe fix it on the underside to limit the disfigurement?I think they still sell the kits at Halfords etc.edit: I type slowly!! BB Quote Link to comment Share on other sites More sharing options...
Guest Posted July 19, 2010 Share Posted July 19, 2010 you need to plastic weld it from the underside, any surplus panel or a plastic coat hanger will suffice, and a soldering iron, its not pretty hence doing it from the underside.also to stop the crack chasing... drill a hole at the end of the crack.. you tube has some funny and some helpful vids on plastic welding, also you can get a 2 pack epoxy, for plastics if thats easier.. Quote Link to comment Share on other sites More sharing options...
BoB3rt Posted July 19, 2010 Author Share Posted July 19, 2010 you need to plastic weld it from the underside, any surplus panel or a plastic coat hanger will suffice, and a soldering iron, its not pretty hence doing it from the underside.also to stop the crack chasing... drill a hole at the end of the crack.. you tube has some funny and some helpful vids on plastic welding, also you can get a 2 pack epoxy, for plastics if thats easier.. Drill a hole? so just have a random hole in the hugger ? I will take a picture tomorrow of the problem and post it up... infact give me 5 minutes and i will steal the Mrs. camera. i think i have heared of using fibre glass... does that fill in the crack?cheers Quote Link to comment Share on other sites More sharing options...
hammer5 Posted July 19, 2010 Share Posted July 19, 2010 i think i have heared of using fibre glass... does that fill in the crack?cheers Its like using cello-tape, it will stop the crack spreading and form a solid bond on the underside. If its a crack it should seal it and if its cleaned up sufficiently hide the crack (maybe)...BB Quote Link to comment Share on other sites More sharing options...
Guest Posted July 19, 2010 Share Posted July 19, 2010 you need to plastic weld it from the underside, any surplus panel or a plastic coat hanger will suffice, and a soldering iron, its not pretty hence doing it from the underside.also to stop the crack chasing... drill a hole at the end of the crack.. you tube has some funny and some helpful vids on plastic welding, also you can get a 2 pack epoxy, for plastics if thats easier.. Drill a hole? so just have a random hole in the hugger ? I will take a picture tomorrow of the problem and post it up... infact give me 5 minutes and i will steal the Mrs. camera. i think i have heared of using fibre glass... does that fill in the crack?cheersno, you fill the hole in afterwards, but a crack will stop at a hole, whereas it will continue to split if left unchallenged..fibreglass will give a bonded weave on the underside, but you may need filler and paint. Quote Link to comment Share on other sites More sharing options...
BoB3rt Posted July 19, 2010 Author Share Posted July 19, 2010 The Damage http://i41.photobucket.com/albums/e293/BoB3rt/DSCF4398.jpghttp://i41.photobucket.com/albums/e293/BoB3rt/DSCF4395.jpgok i will pop to halfords tomorrow to see about the strips, but i may do some plastic welding later in the winter as i am thinking of respraying.bit gutted, but it also looks like it has cracked in a tension spot... ovbiously that would be the most likely place to split but seems to been force fitted!thanks for the help here! Quote Link to comment Share on other sites More sharing options...
BoB3rt Posted July 22, 2010 Author Share Posted July 22, 2010 So i took the hugger off today.Turns out it had already been patched in this area... with what i cant make out, seems to be a botch job.So am thinking of sticking it securly from behind then do some plastic welding to make sure its going nowere hen fill up the front.Hope it works - not done this before will do some pictures. Quote Link to comment Share on other sites More sharing options...
