illvibetip Posted December 12, 2010 Share Posted December 12, 2010 Hello, My bike rev meter goes up to 13,000 and I usually cruise on the motorway (at 80/90mph with pillion) at about 8000 rpm without pushing it too hard ('red' is 12,000 rpm)since this afternoon, when my bike gets up to 7,500/8,000, it seems to have no more power and the revs go up past 8,000 and the bike looses all power. Its as if I knocked it into neutral and am just reving it.Ive been riding it all weekend (around 300km) and never had any problems (apart from it wouldnt start when cold and makes an awful knocking sound until its warm).There are 3 things worth mentioning though as I am a complete novice, I dont know what Im talking about or if this is remotely relevant...1/ it was minus 5 today and windy (so it was bloody cold and id been riding for over an hour when this started.2/ I got the oil changed about 30 mins before I noticed this happening.3/ my bike always did this when I first bought it until a guy i knew fiddled around with it and it stopped. Ive no idea what he did (i think he just played with the idle, not sure).any advice would be great as I dont want to take it to the garage and they say theres nothing wrong with it, i get annoyed, etc.Bike is the Hyosung 250cc 'piece of crap - soon to be traded in on a real make' comet.It has a choke.Four stroke DOHC (air and oil cooled), V2 cylinder engine. Mileage unknown. thanks very much Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted December 12, 2010 Share Posted December 12, 2010 did he put new oil in it and was it motorcycle oil as putting oil designed for cars will make the clutch slip and it sounds like thats what you are describing.revs going up but bike getting no faster Quote Link to comment Share on other sites More sharing options...
illvibetip Posted December 12, 2010 Author Share Posted December 12, 2010 do you think I should change the oil again? it will only cost pennies.cheers btw Quote Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2010 Share Posted December 12, 2010 I'd agree there sounds like clutch slip.First things first I'd try and re-adjust it and make sure its fully in/ out (+check free play).Then next port of call sounds like the oil. Quote Link to comment Share on other sites More sharing options...
illvibetip Posted December 12, 2010 Author Share Posted December 12, 2010 thanks chris.What do you mean 'check free play'? (complete novice here). How would I adjust it, with the clutch cable thing near the engine?ta Quote Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2010 Share Posted December 12, 2010 Well, if you look at your clutch, you should be able to pull it a few mm, this is showing that the clutch is completely engaged. If you can't move the clutch in at all with out it physically tugging the cable/ clutch its self, then it may not be completely engaged, allowing it to slip (esp with the extra weight etc)EDIT: you adjust it with the little nut thing ( ) It should be kind of obvious when you see it, how to do it.If not, either look in the manual or take a photo and post it on here and I or some one else should be able to point it out Quote Link to comment Share on other sites More sharing options...
illvibetip Posted December 13, 2010 Author Share Posted December 13, 2010 thanks, i think i know what youre talking about (the nut). Ill have a look this morning.But first, Im going to change the oil.If it is the oil, is the clutch irreparably screwed? Quote Link to comment Share on other sites More sharing options...
illvibetip Posted December 13, 2010 Author Share Posted December 13, 2010 changed the oil - running as good as ever now.for future reference, its good to know how to adjust the clutch if I have similar problems again.Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted December 13, 2010 Share Posted December 13, 2010 Awesome Quote Link to comment Share on other sites More sharing options...
Stu Posted December 13, 2010 Share Posted December 13, 2010 it could also be a bit of carb icing with it been so cold its a tad warmer then it was last week! Quote Link to comment Share on other sites More sharing options...
illvibetip Posted December 13, 2010 Author Share Posted December 13, 2010 how much would the outside temp. effect the performance/carbs? I was riding for around 40 mins when this happened, but it was minus 5 outside plus the drop in temp with movement/wind. Quote Link to comment Share on other sites More sharing options...
