laverda tel Posted January 16, 2011 Posted January 16, 2011 Hi,got an laverda 668 and want to add a digital speedo but retain original clocks as wellany ideas or advice ??regardstel Quote
andyc Posted January 16, 2011 Posted January 16, 2011 Try a bicycle unit, should run off a magnet on your front wheel. Quote
laverda tel Posted January 16, 2011 Author Posted January 16, 2011 yes,was thinking about these dont know how accurate they are will try onecheers for replytel Quote
CamChain Posted January 16, 2011 Posted January 16, 2011 Magnet type are readily available, but need to specify the ratio. They work fine if set-up and installed correctly. Quote
cypek Posted January 17, 2011 Posted January 17, 2011 I am using one on my chinese 125 as original speedo is dead. If you set correct tyre circumference it is working fine, sometimes even too accurate as it is supposed to overread a bit Quote
laverda tel Posted January 21, 2011 Author Posted January 21, 2011 thanks for repliescheers tel Quote
Danny-B- Posted January 22, 2011 Posted January 22, 2011 Did you end up putting a bike spedo on ? I'm quite interested in doing the same on my CBR now Quote
laverda tel Posted January 22, 2011 Author Posted January 22, 2011 Hi Danny not yet done it been working away will keep you posted on how it goesregardstel Quote
