Ashaman Jay Posted June 7, 2011 Posted June 7, 2011 I've got a fault showing on the FI indicator that means the front oxygen sensor isn't heating.The haynes manual says it won't interfere with the running of the bike or damage the engine, but would you be allowed out on the road for a mod 2 if the examiner saw the FI light?? Quote
rennie Posted June 7, 2011 Posted June 7, 2011 I would think so yes!stick a bit of tape over it! Quote
Bogof Posted June 7, 2011 Posted June 7, 2011 I've got a fault showing on the FI indicator that means the front oxygen sensor isn't heating.The haynes manual says it won't interfere with the running of the bike or damage the engine, but would you be allowed out on the road for a mod 2 if the examiner saw the FI light?? He'll be on his bike before he tells you to start your engine, so he won't ever get to see it. That said, so long as it doesn't compromise safety, it's of no concern to him. Quote
Ashaman Jay Posted June 7, 2011 Author Posted June 7, 2011 He'll be on his bike before he tells you to start your engine, so he won't ever get to see it. That said, so long as it doesn't compromise safety, it's of no concern to him. No safety issue at all as far as I can make out. The heater element is only there to get the sensor up to it's best working temperature right after the bike is started. As soon as it's warmed up there isn't any need for a heater element.I was just wondering if seeing an FI light would mak them cancel the test.That tape idea is in reserve Rennie the light is bloody annoying, and knowing honda I bet a replacement sensor is bloody expensive.I need to start commuting to edinburgh from glasgow from monday, so I really need to pass this mod 2. Quote
fredc Posted June 8, 2011 Posted June 8, 2011 A silver Varadero parks up at the nautical college quite often would that be you Quote
Ashaman Jay Posted June 8, 2011 Author Posted June 8, 2011 A silver Varadero parks up at the nautical college quite often would that be you Not me mate.Mines black. Parked in town center (until Friday). Quote
Stu Posted June 8, 2011 Posted June 8, 2011 what bike is it? cant see it causing a problem at all with the test how many wires has the sensor got can you not short it out to make it think it works ok infact dont do that until after the test you might blow the bike up Quote
Ashaman Jay Posted June 10, 2011 Author Posted June 10, 2011 what bike is it? cant see it causing a problem at all with the test how many wires has the sensor got can you not short it out to make it think it works ok infact dont do that until after the test you might blow the bike up Yeah, I think I'll wait before any soldering gets done.4 wires, 2 for the heater and 2 for the reading.According to another site a resistor across the 2 sensor wires should make it think it's ok. I'll do it after the test tho £200 for a replacement Quote
rennie Posted June 12, 2011 Posted June 12, 2011 well done! welcome to a whole new world Should be, " passed with 2 minors and an F1 light", Quote
