Guys while i was out on the bike in the pouring rain other day water got into the electrics and shorted out the charging circuit... Can you reccommend a good water disperal spray that will also help seal it for future times if i am out in the rain again?..
cheers
mick
White lithium grease is the best for long term use mate, get it from any decent motor factor or vehicle electrical suppliers.
Quick water dispersal can be done with WD40 or GT85 but i would follow this up with white lithium grease in every plug/socket
thanks bud i will use the grease on the multiplugs and get some spray for the actual harness.... :D
is the spray can type lithium grease the same as the tuved stuff mate?
i got 3 tubes of electrical grease off ebay for less then £4 delivered :wink:
if you can pull the connectors apart and clean the contacts first too i pulled all the pins out on mine cleaned them up and put them all back greased up :)
wise choice its good stuff
just dont forget to grease them or something :)
check the connections too as some can work loose and not connect properly
