Hi all
My front brakes are binding. I changed the pads (as they were very low) and replaced the fluid but this did not help.
I pushed the pistons in using a c clamp with plastic cups, replaced the brake fluid, and the calipers are still binding!
I am thinking a bit of dirt or grime is stuck between the brake seals, meaning I need to change them.
Thoughts?
Sounds to me like they need a strip down remove the reals clean behind them clean pistons and put them back together
Unless they are on slides and they are sticking
Cheers, I have greased the slides already, so we can rule that out.
Should I replace the seals when I clean the pistons?
If they aren't leaking why bother? If you can wait till you get them out give them a check over if they look good put them back in
Personally if I were stripping the callipers to clean them I'd put new seals in.....and I'd clean and polish them....and replace all the screws with nice shiney ones.......but then I'm a bit OCD anyway..... :wink:
Hm I would normally, the thing that bugs me is the bike is only 2 years old! (10k miles!)
bit of a pain that they are playing up already!
They are not playing up mate. Pistons bind when they are not kept clean! They are easily ignored , but they cause problems without regular maintenance. If you remove pads occasionally, clean pistons, grease with red rubber grease, push back in and refit pads , you should be OK. :mrgreen: :mrgreen: :mrgreen:
But if you ride in all weathers that salt and crud can really b*gger the brakes up. Strangely lack of use can also be more harmfull than regular use. And binding callipers can cause the disk to overheat and warp it.....
Good point Bob, but a better reason for regular maintenance. After a salt run, I always rinse the calipers off with plenty of water. The first sign of binding and I "exercise " the pistons. :mrgreen: :mrgreen: :mrgreen:
Definitely Alan...... it's brakes that often get overlooked when doing maintenance unless it's a pad change. Worth taking an old toothbrush to the exposed parts of the pistons every now and then.....just to stop the build-up of crud and corrosion as well as keeping the guide pins clean and slightly greased (copper Grease obviously....and the merest smear too)
Good advice Bob. More brakes get fooked up by fitting new pads and lack of cleaning than ignoring em completely!!! :mrgreen:
I had a similar problem when I first got my bike,one of the pistons wasn't seated squarely. I also use emery cloth on pad retaining slider/pins ,they can get little grooves forming from wear and tear. Sound advice with the cleaning,red grease and copperslip though.I do mine every other month.
  • 2 months later...
Hmm I should be more regular with my cleaning sessions...
I'm guilty as charged with this
I did end up removing the pistons, cleaning the seal grooves, fitting new seals and thoroughly cleaning the pistons, they were caked in corrosion! bloody salt on the roads, only 2 years old as well.
