min200 Posted May 8, 2013 Share Posted May 8, 2013 Yet another question!My GSX600R has been dropped at some point by the previous owner and the front brake lever is pretty bent and has some wiggle movement on it.Now is it easy enough to change one of these and if so whats the best way to go about it?Thanks again folks for your help in advance. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted May 8, 2013 Share Posted May 8, 2013 changing the front brake lever is very easy there is the pivot bolt goes through the lever near the master cylinder on the undersie there is normally a 10mm nut undo that and the bolt with either then push out or might need to be wound out if its got a bg slot in the headof bolt then wind it out pull lever out once bolt removed,slot new lever in refit bolt and nut job done Quote Link to comment Share on other sites More sharing options...
min200 Posted May 8, 2013 Author Share Posted May 8, 2013 Thanks for that new lever is now ordered Quote Link to comment Share on other sites More sharing options...
whitedevil Posted May 8, 2013 Share Posted May 8, 2013 5 min job, dead easy. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted May 8, 2013 Share Posted May 8, 2013 they are as easy as changing the clutch lever Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted May 8, 2013 Share Posted May 8, 2013 they are as easy as changing the clutch lever easier a lot of the time as not many front brakes are cable operated Quote Link to comment Share on other sites More sharing options...
Tiggie Posted May 8, 2013 Share Posted May 8, 2013 nothing worse than being outsmarted at being a smartarse Quote Link to comment Share on other sites More sharing options...
min200 Posted May 8, 2013 Author Share Posted May 8, 2013 nothing worse than being outsmarted at being a smartarse Must be my wife in disguise Quote Link to comment Share on other sites More sharing options...
