bashfulpanda Posted September 13, 2013 Posted September 13, 2013 Hello!I recently got a 2008 Honda CBF500. The bike is all good apart from the dash lights don't work. I've checked the fuse box and there isn't a fuse labeled as being responsible for this, so my questions:Does this bike have a dash light? If so - is it how to fix it?CheersTom Quote
Mr Fro Posted September 13, 2013 Posted September 13, 2013 I take it you mean the light that illuminates the clocks? Have you checked the bulb... Quote
Chrissb6 Posted September 13, 2013 Posted September 13, 2013 More than likely blow bulbs, they work on the same circuit as the rest of the lighting system. There a bit fiddly to get at, you might have to remove the clocks to get at them. Quote
Adam Posted September 13, 2013 Posted September 13, 2013 As said above your indicators and lights run on the same circuit so if your indicators work it's not the fuse. Quote
bashfulpanda Posted September 14, 2013 Author Posted September 14, 2013 Cheers for the reply - I'll have to have a look at the bulbs when I have the time! thanks! Quote
