Gazza7682 Posted January 21, 2014 Share Posted January 21, 2014 Hi allJust wondered if anyone can recomend a heater for the garage as its getting quite chilly when working on my project. Thanks in advance guys Quote Link to comment Share on other sites More sharing options...
acting_strange Posted January 21, 2014 Share Posted January 21, 2014 You don't want any kind of gas heater (propane etc) as they produce masses of condensation....I used to have a Dimplex oil filled radiator in mine and that seemed ok... Quote Link to comment Share on other sites More sharing options...
Joeman Posted January 21, 2014 Share Posted January 21, 2014 Since your garage is probably not well insulated, trying to heat the air is pointless.Instead get an InfraRed heater that heats surfaces (like you!) Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted January 21, 2014 Share Posted January 21, 2014 Economical too. Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted January 21, 2014 Share Posted January 21, 2014 I can recommend this one blows hot and cold hopefully we will soon be test the cooling side/! of it http://www.ebay.co.uk/itm/3KW-INDUSTRIA ... 35cdef9f2eHandy also to vent the place when l've been running the motor or welding lol Quote Link to comment Share on other sites More sharing options...
Stu Posted January 21, 2014 Share Posted January 21, 2014 You don't want any kind of gas heater (propane etc) as they produce masses of condensation....I used to have a Dimplex oil filled radiator in mine and that seemed ok... while this is true with it been in a garage there will be masses of condensation already Quote Link to comment Share on other sites More sharing options...
acting_strange Posted January 21, 2014 Share Posted January 21, 2014 You don't want any kind of gas heater (propane etc) as they produce masses of condensation....I used to have a Dimplex oil filled radiator in mine and that seemed ok... while this is true with it been in a garage there will be masses of condensation already I agree but using a gas heater will make rivers.....when I used to fix cars etc for a living we had the big blower ones and you could feel the damp coming off them if you stood in front of one... Quote Link to comment Share on other sites More sharing options...
Joeman Posted January 21, 2014 Share Posted January 21, 2014 You don't want any kind of gas heater (propane etc) as they produce masses of condensation....I used to have a Dimplex oil filled radiator in mine and that seemed ok... while this is true with it been in a garage there will be masses of condensation already Not if you spray your walls with Expanding foam!! condensation free and warm to the touch walls(Photo taken before boarding over the walls in OSB sheet.... which i still need to complete ) Quote Link to comment Share on other sites More sharing options...
Stu Posted January 21, 2014 Share Posted January 21, 2014 I use a huge space heater and don't have rivers!!! Infact I dont even notice any more condensation It heats the place up quickly and end up turning it off after about 20 mins! Quote Link to comment Share on other sites More sharing options...
littlecat Posted January 21, 2014 Share Posted January 21, 2014 I just use a small electric fan heater and make sure its pointing straight at me Quote Link to comment Share on other sites More sharing options...
Adam Posted January 21, 2014 Share Posted January 21, 2014 Put a coat on or move the project into the lounge.. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted January 21, 2014 Share Posted January 21, 2014 I don't have a garage Quote Link to comment Share on other sites More sharing options...
Joeman Posted January 21, 2014 Share Posted January 21, 2014 I don't have a garage you're gonna freeze then mate! Quote Link to comment Share on other sites More sharing options...
Tankbag Posted January 21, 2014 Share Posted January 21, 2014 I don't have a garage you're gonna freeze then mate! Joe this year I am going to shovel my way to victory at the top of the garden & put a base & mega bike shed up there Quote Link to comment Share on other sites More sharing options...
Joeman Posted January 21, 2014 Share Posted January 21, 2014 I don't have a garage you're gonna freeze then mate! Joe this year I am going to shovel my way to victory at the top of the garden & put a base & mega bike shed up there Nice one - look forward to the build thread! Quote Link to comment Share on other sites More sharing options...
Tankbag Posted January 21, 2014 Share Posted January 21, 2014 Nice one - look forward to the build thread! I will post up a thread, for the op I will be using an oil filled electric radiator Quote Link to comment Share on other sites More sharing options...
Gazza7682 Posted January 22, 2014 Author Share Posted January 22, 2014 Thanks for the replies guys. Been told halogen heaters are good and cheap to run. Tho I do like that fan heater advertised. Quote Link to comment Share on other sites More sharing options...
NooBish-AbbZ Posted January 23, 2014 Share Posted January 23, 2014 You don't want any kind of gas heater (propane etc) as they produce masses of condensation....I used to have a Dimplex oil filled radiator in mine and that seemed ok... while this is true with it been in a garage there will be masses of condensation already Not if you spray your walls with Expanding foam!! condensation free and warm to the touch walls(Photo taken before boarding over the walls in OSB sheet.... which i still need to complete ) walls? I don't see any walls in that pic, just a very nice Susie-que Quote Link to comment Share on other sites More sharing options...
JamBerryKing Posted January 25, 2014 Share Posted January 25, 2014 i just end up working next to a halogen floodlight so i can see better and that kicks off enough heat for me Quote Link to comment Share on other sites More sharing options...
