I have here some diesel motor oil... it is the correct grade but obviously isn't designed for my motorbike... would I be alright just topping my oil up, only half a litre or so it needs, but I don't want to run it while the level is low, will it do any harm?
it's nearly due an oil change anyway lol
when you say low how low is it?
if its above the min mark it will be fine till you get the right oil
It's not just the grades you need to look at it's the api ratings too, your bike will require certain ones or you could see things like clutch slip.
If it's last the min just ride to the factors and get some topping up oil
red light may have flickered... so I stopped to check it,
I know bad form :oops:
it's not that I haven't checked it in months... I am aware of a leak and did a long journey yesterday, it was at the correct level yesterday, would seem the leak has got worse, but I'm kinda stranded here unless i can top it up with diesel car oil.... what do you all suggest, I'm not prepared to start it
google hasn't explained anything of the api ratings, you know how they work?
well if I was in your position and the oil light has come on I would be sticking that diesel oil in!!
hopefully no damage has been done
I know... I'm a tit.... i get that, but I don't want to do anymore harm than good
hey I never said you was a tit :lol:
as I say hopefully no damage was done
I have had my oil light on before but for different reasons my oil pump drive gear failed I was doing a great rate of knots!!!
I haven't had any problems with the bike
that's a weight off of my mind lol.... so you reckon the derv oil will do the job?
that's what I figured lol... I'll change it all at the same time as I change the leaky gasket, probably at the weekend when I'm not in work
Any oil is better than none.
What weight is the diesel oil? It might not be far off what you need ;)
IMO any oil is better than no oil regardless of api ratings and stuff!!
:stupid: Totally agree, but yes like tyres and the rest of the bike always better looking at it rather than for it.
I have bought a gallon of oil and the required gasket, I have topped it with the diesel oil I had here, took more than I expected... now I really feel bad lol
I will change it at the weekend, hopefully the derv oil won't do any harm in there
