Nic Posted April 14, 2015 Posted April 14, 2015 Hi all,Just wondering if any of you guys can recommend a good set of earplugs please?I currently use auritech but find them really uncomfortable after a while and one of them always pops out!Thank you Quote
RantMachine Posted April 14, 2015 Posted April 14, 2015 WHAT? SAY THAT A BIT LOUDER, I'VE RUINED MY HEARING SOMEHOW Quote
Chrissb6 Posted April 14, 2015 Posted April 14, 2015 Hi all,Just wondering if any of you guys can recommend a good set of earplugs please?I currently use auritech but find them really uncomfortable after a while and one of them always pops out!Thank youHi, in most cases if the ear plugs are not comfy or they keep dropping out your not fitting them properly.Try this wayhttp://www.dadepaper.com/Content/Produc ... 3ac61a.pdfAuritech plugs are as good as they get, you shouldn't really be having this problemHope this helps Quote
Guest Posted April 14, 2015 Posted April 14, 2015 try a selection pack.. heres an example. not expensive. there may be some that are perfect for you and once you know which.. just order more of them.http://www.ebay.co.uk/itm/Foam-earplug- ... 4cfe94031dhttp://www.ebay.co.uk/itm/Foam-Earplugs ... 3a8303cecf Quote
Nic Posted April 14, 2015 Author Posted April 14, 2015 Hi all,Just wondering if any of you guys can recommend a good set of earplugs please?I currently use auritech but find them really uncomfortable after a while and one of them always pops out!Thank youHi, in most cases if the ear plugs are not comfy or they keep dropping out your not fitting them properly.Try this wayhttp://www.dadepaper.com/Content/Produc ... 3ac61a.pdfAuritech plugs are as good as they get, you shouldn't really be having this problemHope this helps Great thank you - it is most likely me Quote
Nic Posted April 14, 2015 Author Posted April 14, 2015 try a selection pack.. heres an example. not expensive. there may be some that are perfect for you and once you know which.. just order more of them.http://www.ebay.co.uk/itm/Foam-earplug- ... 4cfe94031dhttp://www.ebay.co.uk/itm/Foam-Earplugs ... 3a8303cecf Thank you for these, will also check them out Quote
adekeys Posted April 14, 2015 Posted April 14, 2015 got a set of these very comfy and a lot quieter!http://www.ultimateear.com/motorcyclist.php Quote
hadster Posted April 14, 2015 Posted April 14, 2015 http://www.screwfix.com/p/stanley-sy330 ... lugs/69698I have just this evening moulded myself a set of these Quote
Stu Posted April 14, 2015 Posted April 14, 2015 Over the years and many different earplugs I have found these to be the best and comfiest for me http://www.ebay.co.uk/itm/3M-EAR-Soft-F ... 19ded718bf they are the highest SNR I have seen at 39db they are really comfy too and easy to insert Quote
Zulueleven Posted April 14, 2015 Posted April 14, 2015 Again I have to agree with Stu they are the most comfortable and kill the noise,best bought in bulk works out a lot cheaper Quote
fq-craigus Posted April 14, 2015 Posted April 14, 2015 Raid the door pocket of a highway maintainence vehicle and nab a few pairs every now and again that they use for the jack hammer. Thats what i do Quote
techno Posted April 15, 2015 Posted April 15, 2015 Again I have to agree with Stu they are the most comfortable and kill the noise,best bought in bulk works out a lot cheaperTried those they were and still are awful, I need the more barrel shaped expanding ones but I use moulded earplugs I got from work now, by far the best. Quote
Nic Posted April 15, 2015 Author Posted April 15, 2015 Thank you for all the responses chaps. Much appreciated Quote
dazziep Posted April 15, 2015 Posted April 15, 2015 I tried the cheap disposable foam ones last night and the were really good.. Quote
Guest Posted April 15, 2015 Posted April 15, 2015 I tried all sorts of plug but could never get a good fit. I appear to have unusually shaped canals.I have now used Ultimate moulded plugs for many years, and they work. Quote
Joeman Posted April 15, 2015 Posted April 15, 2015 Problem I find with moulded plugs is that if they move very slightly the seal breaks and all the noise comes in.I much prefer the spongy ones when installed correctly. Sometimes takes a couple of attempts but once there are in, everything is peaceful. Quote
