WonderAve Posted July 2, 2015 Share Posted July 2, 2015 Honestly, this bike ia doing my head in today. I've fitted 4 x LED indicators and put the included relay in place of the original. Lights very dimly stay lit (all 4, all the time). I have 2 r&g indicator inline resistors. Do I need 2 more? One for each indicator? Will this make them work? I thought I could put 1 in the right circuit and 1 in the left circuit and this would be enough. Now with 1 resistor in the right circuit, and the new relay, nothing lights up. With the same resistor in the right circuit, and the old relay (for the conventional bulbs), when flashing left only the left stay on, when right, they all just stay on. Bit much more brightly than before. Any ideas? I only put the one resistor in to test the right circuit before I messed about putting the left one in and for it to not work. Thanks guys, WonderAve. Cbr125 Quote Link to comment Share on other sites More sharing options...
WonderAve Posted July 2, 2015 Author Share Posted July 2, 2015 Put the other resistor in and now they light up at correct times with old relay but no flash. New relay, they don't light up at all, Duff relay?? Quote Link to comment Share on other sites More sharing options...
Stu Posted July 2, 2015 Share Posted July 2, 2015 LED relays are hit and miss some work some dont! I would always go the resistor route you would need one on each circuit depending on the size of the resistors, you may need two on each circuit Quote Link to comment Share on other sites More sharing options...
