fz6 fazer - change speedo
Varish
I brought my bike up here from Italy (fz6 fazer 600 2004) and.. i discovered I can't change the speedo from km to miles. I suppose I need to change it, but it cost a lot of money I don't want to spend right now.. is there any (cheaper) speedo I can mount on it? or is there a setting I have to change internally?
I also found the clock only for 55£ on ebay
£55 for a new clock?!? Mine is £145 for a second hand one and it's only an analogue dial :cry:
not new at all :) it's second hand, new it cost 200 or so. But, can't I do the same thing changing some cable or electronic stuff? damn, really Yamaha did two different clocks for different models? it should be really the same.
Get a marker pen and draw the MPH speed on it.
Shame that it's electronic...
Lol in that case a speedo healer would work
Where I can find them? I tried and I haven't found anything, the only one I found cost me more than the new clock.
yeah, I read it. Unfortunately the select button doesn't work, and I am trying to find this magic speedohealer..
--- EDIT ---
Ok, nevermind! I found the speedo healer for about 50£ in an italian website. The question still remain.. does changing the clock resolve the problem? because that seems easier to me and I don't have any external product to add.
you should be able to toggle between MPH and KPH on the clocks
its a legal requirement
fitting new clocks will either read KPH or MPH if they are KPH you will have to change them to MPH
or fix your select button on your to make yours work
