Ok so my gear position switch does not work anymore and I'm looking for a replacement. Now finding these anywhere is quite hard so would one from any other suzuki with the triangle shaped white plug with 3 pins work?
It's bloody annoying as I can't leave the bike in neutral with the side stand down as it just cuts out. Is a neutral safety switch compulsory for mot?
the majority of these switches never actually fail!
they just need removing and cleaning up
Well I was changing the bulb for the neutral light and I accidently shorted it out. Would this cause the gear position switch to not work?
http://i713.photobucket.com/albums/ww138/Seany205GTI/Mobile%20Uploads/20160325_194723_zpsdpwh7i4k.jpg
The sensor in question
Is that your front sprocket?...... :shock:
I was thinking the same!
it needs replacing along with the rear and the chain!
And yes it did work. The light was working and everything but the bulb needed juggles about. I decided to squeeze the connections more.closely.together stupidly. Forgetting to disconnect.the battery. Now the light won't work at all
It doesnt matter
if you are getting power to the bulb holder then you have a contact issue with the bulb
if no power then start working backwards towards the sensor
check all three wires for power and stick the earth to the battery from the multimeter
We're not having a go at you mate.....but as EAB says, you'll knacker your new chain with that sprocket.....best change it as soon as you can..... :)
luckily enough i have a shifter spanner here which fits at the limit of its adjustment. big bar here also. i'll flatten the lock washer tomorrow and have a go at loosening it! i know its not good for the chain but i had to take it on a quick test drive today after fixing the carb
it will be bloody tight you might need a mate or someone to push hard on the rear brake and mind the adjustable spanner doesnt slip off as we all know how skinned knuckles hurt
going to have a big piece of scaffold piping over the spanner for leverage so no chance of skinned knuckles. anyway back to the point. i bought a sensor off a 02 gsxr600. it was very cheap and looks very similar so what the hell! i know the gixxers are 6 speed and mine is 5 but the neutral part is all im worried about!
