Guest Posted June 9, 2016 Share Posted June 9, 2016 I've not been able (said allowed) to ride my bike for a couple years but in that time i have added braided hoses and turned the damper up a bit the tyres were brand new when it was last ridden (march 2014). But now on "entertaining rides" and slow moving town riding i seem to be locking the rear wheel so easy Any ideas where to start? Im thinking the braided hose is the issue Quote Link to comment Share on other sites More sharing options...
bmwdave Posted June 9, 2016 Share Posted June 9, 2016 I'm no expert but I thought the whole idea of braided hoses was to firm up the brakes, so you'll have to learn a gentler touch to stop locking up the back. Remember if the front is biting more you'll get more dive so the back gets lighter and locks up easier. Quote Link to comment Share on other sites More sharing options...
bonio Posted June 9, 2016 Share Posted June 9, 2016 I'm not on expert either, but it sounds like you're being too heavy on the back brake. I guess yo could go out somewhere quiet and try out braking with different amounts of pressure. Only don't go wild and bin it [WHITE SMILING FACE]Sent from mTalk Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 9, 2016 Share Posted June 9, 2016 replace the fluid with old bubbly stuff to soften up the brake... or learn to be less heavy footed Quote Link to comment Share on other sites More sharing options...
Guest Posted June 10, 2016 Share Posted June 10, 2016 replace the fluid with old bubbly stuff to soften up the brake... or learn to be less heavy footed The black fluid was clashing with the frame I'm no expert but I thought the whole idea of braided hoses was to firm up the brakes, so you'll have to learn a gentler touch to stop locking up the back. Remember if the front is biting more you'll get more dive so the back gets lighter and locks up easier.This sounds likely, hadn't thought about that Only don't go wild and bin it [WHITE SMILING FACE]Sent from mTalkIts a supermoto its always wild Thanks for the inputs guys, looks like its rider error then than set up Quote Link to comment Share on other sites More sharing options...
Stu Posted June 10, 2016 Share Posted June 10, 2016 Eat more pies! It won't lock up as easy! Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted June 10, 2016 Share Posted June 10, 2016 i thought the idea was to get the back tyre on the point of locking and skipping to help it slide round the corners..........................but on a more realistic note as others have said braided hose doesnt flex like rubber ones so it will be firmer and more positive so dont press it as hard Quote Link to comment Share on other sites More sharing options...
Guest Posted June 10, 2016 Share Posted June 10, 2016 Eat more pies! It won't lock up as easy! Is there a brand or flavour that works best? Quote Link to comment Share on other sites More sharing options...
Stu Posted June 10, 2016 Share Posted June 10, 2016 trying them all will have good results Quote Link to comment Share on other sites More sharing options...
Guest Posted June 10, 2016 Share Posted June 10, 2016 trying them all will have good results All in one go? Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted June 16, 2016 Share Posted June 16, 2016 No - staged over time. Say, 1 pie per 5 minutes for 12 hours should do it.PS. Melton Mobray family sized Pork Pies are the most effective. Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 16, 2016 Share Posted June 16, 2016 Install a pie oven on the bike so you can have a constant supply of hot fresh pies.And a cutout in the front of your helmet to feed them into your face.And a robot arm to take them from the oven, wave them about to cool down before shoving them through the piehole.That should fix your back brake. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 16, 2016 Share Posted June 16, 2016 No - staged over time. Say, 1 pie per 5 minutes for 12 hours should do it.PS. Melton Mobray family sized Pork Pies are the most effective. I was having the trouble on the way to melton, maybe its a sign Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted June 18, 2016 Share Posted June 18, 2016 I too have 'trouble' on the A606 - The throttle always seems to wind itself open! The best pies are the 'hand-sealed' ones, I've watched these being made in the 'factory' in Melton. The 'crafter' always remembers to lick his fingers between pies! Quote Link to comment Share on other sites More sharing options...
Guest Posted July 6, 2016 Share Posted July 6, 2016 The pie theory has gone wronghttp://i268.photobucket.com/albums/jj21/charlie_t_photos/Mobile%20Uploads/Snapchat-7363851002217799420_zpscnsfh4vd.jpg Quote Link to comment Share on other sites More sharing options...
Stu Posted July 6, 2016 Share Posted July 6, 2016 You now need a smaller tyre......... Quote Link to comment Share on other sites More sharing options...
Guest Posted July 9, 2016 Share Posted July 9, 2016 Keep rubbing like that it soon will be smaller Quote Link to comment Share on other sites More sharing options...
