grunthorpe Posted June 18, 2016 Share Posted June 18, 2016 Good morning all,A friend and I recently bought radios with those headsets with a sticky pad speaker a mic that's supposed to hide behind your cheek pads. The problem is, my helmet is such a snug fit, that this solution doesn't really fit inside my helmet no matter what I do.Has anybody here experienced this problem? Is there a less bulky option? (I'm expecting there's something really obvious and I'll look stupid Cheers,NickSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 18, 2016 Share Posted June 18, 2016 I had the same problem. So I bought a headset that uses earbuds instead of speakers. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2016 Share Posted June 19, 2016 When you say hide behind your cheek pads are you literally trying to put them behind the cheek pads or just beside the lining? Most helmets have cut outs for your ears and the speakers sir in there Mine are just sat behind the lining and not behind the cheek pads Quote Link to comment Share on other sites More sharing options...
Joeman Posted June 19, 2016 Share Posted June 19, 2016 Mine has the cutouts in the polystyrene that the speakers fit perfectly. Unfortunately my ears are in the wrong place - the speakers line up behind my ears so road/wind/engine noise are a huge problem.In my case it's best to just use earbuds. Quote Link to comment Share on other sites More sharing options...
grunthorpe Posted June 19, 2016 Author Share Posted June 19, 2016 Sorry, I should have clarified, the mic is the bit that caused the main issues, there's no room for it anywhere, the speaker sticks into the gap where my ears go fine, but it's all one unit Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted June 19, 2016 Share Posted June 19, 2016 Do you not have the ability to use a different mic? If you can plug another in you want a wired mike. I take it that it on the end of a boom at the minute? Quote Link to comment Share on other sites More sharing options...
grunthorpe Posted June 19, 2016 Author Share Posted June 19, 2016 Yeah it's a boom mic, is there like a small type you can hide away somewhere? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted June 19, 2016 Share Posted June 19, 2016 what headset is it? Quote Link to comment Share on other sites More sharing options...
JamBerryKing Posted June 19, 2016 Share Posted June 19, 2016 i had this issue with my agv k3, trying to fit the boom mic in from my scala wasn't having it, but scala provided a second mic that is just a thin cable, with a flat circular mic on the end, that you can then secure in place with a sticky pad. job sorted.i had no issues with the boom mic in my shoei qwest though. Quote Link to comment Share on other sites More sharing options...
grunthorpe Posted June 21, 2016 Author Share Posted June 21, 2016 i had this issue with my agv k3, trying to fit the boom mic in from my scala wasn't having it, but scala provided a second mic that is just a thin cable, with a flat circular mic on the end, that you can then secure in place with a sticky pad. job sorted.i had no issues with the boom mic in my shoei qwest though. This is the helmet I am having an issue with, so it's not just me I'll just have to have another look around then... Thanks!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
