Foxy Stoat seeks Pig Posted October 25, 2016 Posted October 25, 2016 I have heated grips installed which have wired directly to the battery. Which of course means that i know at some point i'm going to leave them on/accidently knock the switch and come back to the car park and find i have a flat battery OR some tool is going to switch them on 'for a laugh'.So is there a way to easily wire these to the ignition, reading up it seems i need a relay and a live wire, possibly the tail light? Willing to have a crack myself if its fairly straightfoward. Quote
Glorian Posted October 25, 2016 Posted October 25, 2016 Had my father do mine as he is qualified electrician and i hate electrics.But i had mine done the same way. Afraid i can't explain how it is done, but it's do-able!Think mine actually came off the horn as it was easier to access. Quote
dave_d Posted October 25, 2016 Posted October 25, 2016 Loads of topics about this. Yes... its fairly easy, as long as you can find an accessible switched live. I think I was using the side light on my CBF which was accessible where I would be placing the rest of the wiring. Its best to use relay as you have stated so that you supply your own power through dedicated cables. The strom was easier as there are actually dedicated points to connect to which are already switched. The oxford ones have a 'power save' mode anyway. So they automatically turn off if you forget if they feel the battery gets to low, or they cant feel/hear (?!?!) engine noise/vibration. On the two pairs I have tested, they seem to work. Quote
JRH Posted October 25, 2016 Posted October 25, 2016 Very simply, thishttps://wardiesworld.files.wordpress.com/2011/02/circuit_grips.gif" onclick="window.open(this.href);return false;http://images.mcn.bauercdn.com/forumgallery/7/691707/168169_514582.jpg" onclick="window.open(this.href);return false; Quote
Foxy Stoat seeks Pig Posted October 25, 2016 Author Posted October 25, 2016 Thanks all, might give it a go. Oxford power save sounds like a good idea...shame mine are R&G Quote
Stu Posted October 25, 2016 Posted October 25, 2016 you can buy the oxford controller and wire that in to your grips if you really want but a switched live is easy Quote
Foxy Stoat seeks Pig Posted October 25, 2016 Author Posted October 25, 2016 Cheapest option will be the winner, few quid for a relay looks favourite. Quote
Stu Posted October 25, 2016 Posted October 25, 2016 Yeah thats the way I would go are you planning on fitting any other accessories that may need a relay? If so check this out http://themotorbikeforum.co.uk/viewtopic.php?f=83&t=59453" onclick="window.open(this.href);return false; Quote
Dav3y Posted October 26, 2016 Posted October 26, 2016 Made the mistake of wiring my first set of grips directly to the battery. I altered the wiring after leaving them on not once but TWICE !!Fairly simple process. Remove the live supply feeding the grips fuse holder from the battery and connect it to a switched live going into the back of the fusebox. To find the live side of the fuse in the fusebox, remove the fuse and check for 12v with a meter or small 12v bulb with the ignition on. Headlight fuse is a good one to aim for. There's no point wiring to the load/out side of the fusebox fuse as your grips will have their own one and you would then need to uprate the fuse in the fusebox to accommodate the extra load. Depending on the bike, there might even be an accessory connector for exactly this type of purpose (if you can find it !) that you could use instead. Never faffed around with a relay, overcomplicated for what's probably no more than a 3A current draw.The additional load should be negligible to cause any problems overloading the switching contacts of the ignition switch. Quote
Grumpy Old Git Posted October 27, 2016 Posted October 27, 2016 Fit a relay: Cheap, safe and easy to do. No worries about overloading any circuit, or getting a flat battery.Also, for even better 'safety', fit an in-line fuse to the (relay switched) feed from the battery (fuse rating dependant on maximum load of your heated grips and/or other accessories).If you want a wiring diagram and parts list, PM me your email and I'll 'ping' you one. Quote
Foxy Stoat seeks Pig Posted October 27, 2016 Author Posted October 27, 2016 I have ordered a fused 4 pin relay. Have some wire somewhere and some spade connectors, although you can be sure they will be the wrong size. Quote
Foxy Stoat seeks Pig Posted November 4, 2016 Author Posted November 4, 2016 Ok, so it happened.....got out of work and flat battery. three hours later I get home. Of all the days to forget my phone as well, wife was very worried. God bless the biker parked next to me who lent his phone to the RAC. Quote
Tango Posted November 5, 2016 Posted November 5, 2016 Ok, so it happened.....got out of work and flat battery. three hours later I get home. Of all the days to forget my phone as well, wife was very worried. God bless the biker parked next to me who lent his phone to the RAC.You didn't use a relay then?..... Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 No, haven't done anything to it yet. So very annoyed with myself yesterday, although I know I turned the grips off. The RAC check the battery and said it only charges to just over 11volts and should be more. Do I need a new battery? aswell as sorting the grips of course. Quote
Stu Posted November 5, 2016 Posted November 5, 2016 If it's only charging at 11 volts then you need to look at the charging system Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 If it's only charging at 11 volts then you need to look at the charging system Oh dear, changing a battery sounds simple, looking at the charging system doesn't Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 I've removed the fuse in the heated grips as a temporary fix. hope that doesn't cause any other issues. Quote
Stu Posted November 5, 2016 Posted November 5, 2016 removing the fuse will do nothing for the charging system Have you got a multimeter? we can teach you Its not as hard as it sounds Quote
Tango Posted November 5, 2016 Posted November 5, 2016 Yep......it's just a case of putting a multimeter set to volts dc across the battery terminals and taking down the voltage readings at different stages......as Stu says, we can help you with this..... Quote
Guest Posted November 5, 2016 Posted November 5, 2016 Yep......it's just a case of putting a multimeter set to volts dc across the battery terminals and taking down the voltage readings at different stages......as Stu says, we can help you with this..... Making sure its not on the ammeter setting as my favourite trick Quote
Mr Fro Posted November 5, 2016 Posted November 5, 2016 Making sure its not on the ammeter setting as my favourite trick Did that with my Fluke - bloody £18 for a new fuse! Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 removing the fuse will do nothing for the charging system Sorry, I meant regarding the leaving the grips on/someone switching them on and leaving me left in the car park. I figured its only a short 15-20 mins ride to work and I could just wear my winter gloves. Rather that than spend 3 hours in a cold dark car park. Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 removing the fuse will do nothing for the charging system Have you got a multimeter? we can teach you Its not as hard as it sounds I don't have a multimeter but could be an essential piece of kit. I'm keen to learn so will be one up and will seek advice how to use it Would one from Screwfix (cheapness)do or should I get one from Halfords?Really enjoyed tinkering today. still trying to work out which wire is the tail light before snipping anything and I have a negative wire from the battery that runs right to the back of the bike and then seems to end in a connector that isn't being used. Also discovered I have a K&N filter but no idea how to clean it yet so I left in well alone. Quote
Stu Posted November 5, 2016 Posted November 5, 2016 any multimeter will do for now you can pick them up for peanuts Quote
Foxy Stoat seeks Pig Posted November 5, 2016 Author Posted November 5, 2016 something like this?http://www.screwfix.com/p/lap-mas830b-digital-multimeter-600v/75337?kpid=75337&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&gclid=CPmFxbbBktACFbcK0wodHkQPzg#product_additional_details_container Quote
