Cougar dave Posted January 24, 2017 Share Posted January 24, 2017 Hi everyone, I'm adding some spot lights and USB charger to my Son's bike (varadero) and I want them to have power only with ignition on , so lights will be going through a relay ,can anyone tell me if USB charger can go through the same relay. Or do I even need a relay any advice appreciated. Quote Link to comment Share on other sites More sharing options...
Tango Posted January 24, 2017 Share Posted January 24, 2017 You should be able to run the USB charger socket through the same relay, assuming the total current doesn't exceed the relays rating..... USB sockets can draw a small amount of current even with nothing plugged into them, so running it through a relay is generally a good idea..... Quote Link to comment Share on other sites More sharing options...
Cougar dave Posted January 24, 2017 Author Share Posted January 24, 2017 Thanks tango will get on with that tomorrow . Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted January 25, 2017 Share Posted January 25, 2017 You should be able to run the USB charger socket through the same relay, assuming the total current doesn't exceed the relays rating..... USB sockets can draw a small amount of current even with nothing plugged into them, so running it through a relay is generally a good idea..... Relay (fused) every time - better safe than sorry! How to wire it all up is/has been posted on t'forum a couple of times - I even provided 'Maplin' part numbers once. Quote Link to comment Share on other sites More sharing options...
Cougar dave Posted January 25, 2017 Author Share Posted January 25, 2017 Quote Link to comment Share on other sites More sharing options...
