Cougar dave Posted May 1, 2017 Posted May 1, 2017 Hi everyone, I was planning to take off carbs to give them a good clean today but when I took tank and air box off I just could not see how it was possible to even see the clips that hold the carbs on never mind loosening them so I put it all back together and was thinking maybe put some kind of additive in fuel to clean them , is red x any good for bikes? Quote
Hoggs Posted May 1, 2017 Posted May 1, 2017 I adore redex it's probably not a proper fix but it seems to help Just make sure you buy the stuff suitable for carbs Quote
Stu Posted May 1, 2017 Posted May 1, 2017 Redex is OK for getting a bit of gumming out the carbs but if you feel they need a clean then nothing is better than a strip Quote
Tango Posted May 1, 2017 Posted May 1, 2017 Pretty comprehensive instructions here.....http://www.yzf600r.com/phpBB2/viewtopic.php?t=38920 Quote
Cougar dave Posted May 1, 2017 Author Posted May 1, 2017 Thanks ,will try the red x for now but will try taking carbs off at a later date excellent link tango Quote
iangaryprice Posted May 2, 2017 Posted May 2, 2017 Redex is worth a try. It does help remove some dirt etc.It can also help remove water which is another sourceof trouble in carbs.One of the car programmes did a test on it (actually a fue injection engine).It actually turned out to be the most cost effective way to increase power. Quote
