Jasperjay Posted May 6, 2017 Posted May 6, 2017 I have a derbi terra 125 as abov in the title and I came off on a dirt track. I have snapped of my gear lever shaft I will attach pictures aswell and I'm not sure on the best fix , eill I need to open up the engine or do you think I could get away with a metal lever and weld it on? Any advice is very much appreciated Thanks J Quote
Stu Posted May 6, 2017 Posted May 6, 2017 hi and welcome to the forum you need to buy and fit one of these https://www.ajsutton.co.uk/product/piaggio/847236/shaft-selector-assy?uid=0 make sure it is the correct one for you bike though Quote
fastbob Posted May 7, 2017 Posted May 7, 2017 You definitely need to fit a complete new shaft BUT don't assume that you have to split the whole engine. There is a chance that it can be withdrawn and pushed through from the other side . Can't be sure though so please study the manual first. Good luck. Quote
iangaryprice Posted May 7, 2017 Posted May 7, 2017 As above study hte manual. If you are lucky it will be accesible by removing the clutch cover onthe other side of th eengine. You may also need ot remove the clutch.Welding it will cause heat damage to at least the oil seal for the shaft if not more. Then you will have problems with future maintenance. Quote
