savo318 Posted July 25, 2017 Share Posted July 25, 2017 Yes its me again sorry .Going in to work this morning (4 oclock), i noticed that my headligt was very yellow and very weak. From i can see on the net this is normal for a honda cg. but to be honest im not very happy with it.is it possible to replace the headlight or at least the bulb with haloen or led, and if so, whatsort of wattage voltae should i be looking at.thanks Quote Link to comment Share on other sites More sharing options...
Stu Posted July 25, 2017 Share Posted July 25, 2017 Replace like for like otherwise you may end up seeing less or blinding oncoming cars You can buy better bulbs of the same fitment As for wattage stick to the same as you could melt the headlight or the wiring! Quote Link to comment Share on other sites More sharing options...
